Shower goes cold...
Discussion in 'Shower & Bathtub Forum & Blog' started by steveg91, Jul 7, 2008.
  1. steveg91
    steveg91 New Member
    Aug 14, 2006
    Hey folks, While taking a shower, it'll go cold periodically, then back to regular, then cold, etc. We have a large water heater. THe shower valve is single handle, could it be the valve??
    Thanks,
    Steve
  2. jadnashua
    You could have some crud in the line that is moving back and forth with pressure changes, or tumbling, changing the amount of hot that gets to the valve. Is the pressure changing when this happens, or only the temp?
  4. hj
    cold
    IT could be any number of things but can only be diagnosed by someone at the house checking when and why it happens.
  5. steveg91
    steveg91 New Member
    Aug 14, 2006
    Hi Jim, The temperature is the only thing that changes.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    You may have an older non pressure balanced mixer. If someone else in the house uses water the temperature will fluctuate.
    If you do have a pressure balanced mixer the balancing valve may be stuck.
    What do you have for a mixer valve?
Similar Threads: Shower goes
Shower & Bathtub Forum & Blog Water goes down slowly in Tub/ shower Jun 26, 2016
Shower & Bathtub Forum & Blog Delta shower slowly goes from hot to lukewarm Mar 16, 2015
Shower & Bathtub Forum & Blog Plastic shower arm goes round 'n' round Dec 19, 2006
Shower & Bathtub Forum & Blog Shower head goes Gulp Drip Gulp Drip Sep 16, 2005
Shower & Bathtub Forum & Blog Symmons / Temptrol valve, Water comes out of tub spigot when shower is on - New diverter did not fix Yesterday at 7:02 PM
