Shower Glass Block Wall
Discussion in 'Shower & Bathtub Forum & Blog' started by Stat Man, Dec 24, 2010.
  1. Stat Man
    Stat Man New Member
    Dec 4, 2009
    Cedar Rapids, IA
    Looking to build two glass block walls for a tiled shower. Both walls would be anchored only on the bottom and one side. Has anyone used any of the mortarless glass block installation systems?
  2. jadnashua
    My personal opinion is that's not a great idea. I'd discuss this at www.johnbridge.com Tile Your World website...there are a number of people that have done showers with glass block and you'll get some helpful opinions from tiling pros.
  4. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    [​IMG]
    Love this cartoon.
  5. Stat Man
    Stat Man New Member
    Dec 4, 2009
    Cedar Rapids, IA
    I followed the link and looked at some of the shower projects. When I click on "View Easy-To-Use Installation Guide" it brings up the ProVantage II info. Isn't ProVantage II a mortarless system?
  6. jadnashua
    If your glass block walls are going floor to ceiling, then they'll have decent support...but, if they are free-standing, and terminate below the ceiling, then I think you'll have problems...fall against it once, and it might just come down.
  7. jadnashua
    If you are talking about John's COPYRIGHTED book, then if it is available free, it is illegal. He, rightfully, charges a nominal fee for it. If you feel comfortable stealing it, then that's up to you.
  8. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    ... uhh I believe he was referring to the fact that that there is plenty of free kerdi and tile setting info available on the net, like on youtube! And I do own a copy of John's tilesetting book, as well as a copy of his kerdi book. Both are excellent and worth more than he charges for them, I just wish his books included more pictures and examples.
    happy chrismahanukwanzakah
  9. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    [​IMG]
  10. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    I've been called out to homes with water leaks originating from bathrooms that reveal glass block installations, and 100% of the time the installer incorrectly performed the work.
    I'm 3 for 3 on diagnosing these on the ones that people thought it was instantly a plumbing leak, which in essence it was a block-meets-floor leak or block-intersects-wall.
    Setting that wall on just subfloor instead of 1" of solid wood was to blame, most times. No expansion joints (siliconed instead of mortared) was another fault in the design.
    The last one I diagnosed, they ended up tearing the whole shower down and doing it over. How's that for doing it twice.
  11. Stat Man
    Stat Man New Member
    Dec 4, 2009
    Cedar Rapids, IA
    Thanks for all the info so far!!!
    I'm planning on these glass block walls (maybe 1/2 walls is a better descriptor) sitting on top of 30" or 36" high stub walls (correct terminology?). I was hoping to also have 1x6 granite slabs on top of those stud walls to act as the base for the glass block. Any issues with doing this?
  12. Stat Man
    Stat Man New Member
    Dec 4, 2009
    Cedar Rapids, IA
    Here's a rough floorplan. The "S" is the showerhead, "C" is the curb, "=" are the glass block walls on the pony walls. It will be roughly 50" wide (left to right), 48" from the top to the first glass block wall, and 80" overall length (top to bottom).
  13. jadnashua
    For the record, I (as indicated in my tag line) am a retired, defense industry systems engineer. Spent a lot of time with highly complex systems and have a good idea how things work and how they go together. I get nothing from either Terry or John Bridge for my posts on either forum. I found both of these websites years ago when I was beginning some remodeling projects, and read a huge amount of info to try to learn how to do things the right way. In the process, I did take a class at the TCNA facility that was sponsered by Schluter. I was exposed to various methods, but found Kerdi to be both available and it just met my criteria as a good, reliable, robust system. I push people to John Bridge's site when a tiling question comes up because it is populated with a great amount of professional tilemen, and you'll get a huge background in opinion and a fairly quick turnaround including more than one opinion. If you take the time to read my posts, I never profess myself as a plumbing, etc., pro, but most of the time, I'm pretty accurate (and, I hope, well intentioned). I get nothing from Schluter if I promote their products, either...I just believe they do make a good one, but offer other choices in most cases. Many of the pros on the Tile Your World website have been in the business for decades, and many of them have come to believe in surface membranes, with Schluter being the most popular. They will help you build a conventional shower as well as any other approved method, and include an extensive amount of info in the 'Liberry' on that. There are people here that feel they got bad advice there - but, my feeling is that either they took the advice the wrong way, or they didn't stick around long enough to let the alternatives be presented to them. Just like here, and any forum, sometimes the first answer may not be the greatest, and if you don't stick around, you may get a bad impression or even totally incorrect info.
  14. Stat Man
    Stat Man New Member
    Dec 4, 2009
    Cedar Rapids, IA
    Open entry
    I know what flush means, but not sure I get the distinction your talking about.
    6x6 for walls, 1x1 or 2x2 for floor.
    The glass block is 8x8x4. One wall will have 24 blocks, the other 18. Wanted to stop these walls about a foot short of the ceiling, any way to do that?
    Yes, a bench in the corner. Two niches.
    No access from below, and I'm doing the framing.
  15. Stat Man
    Stat Man New Member
    Dec 4, 2009
    Cedar Rapids, IA
    So it's time to build my pony walls. One will be 25" wide and 35" tall, the other will be 33" wide and 35" tall. Both will be perpendicular to the floor joists and each will attach to full height walls on one end. Is there a way to make these walls rigid without opening up the floor to attached studs to the floor joists?
Similar Threads: Shower Glass
Shower & Bathtub Forum & Blog Shower glass installation - less than 1/8" gap between U-Channel frame and glass acceptable? Jul 31, 2015
Shower & Bathtub Forum & Blog Replacing a fiberglass shower pan, keeping wall tile - possible? Mar 6, 2015
Shower & Bathtub Forum & Blog Delta Shower Faucet in Fiberglass Shower; Hole Size? Remove Plaster Guard? Jan 31, 2015
Shower & Bathtub Forum & Blog Which Mortar for Bed for One-Piece Maax Fiberglass Shower? Jan 16, 2015
Shower & Bathtub Forum & Blog Glass shower doors Aug 4, 2014
