Shower from hell
Discussion in 'Shower & Bathtub Forum & Blog' started by bendal, Mar 24, 2005.
  1. bendal
    bendal New Member
    Mar 23, 2005
    I have a stripped out connector where the shower arm screws in. I cannot get to it to replace it without tearing out the tile. (The other bathroom is on the other side of the wall, tile there too, can't go in that way either) Is there something that fits inside the shower and not in the wall? It would have to hook up at the bottom of the shower stall and run up inside the shower and attach to the wall. I have an access panel at the bottom of the shower and would have to hook on there. I have seen some that hook on where the shower arm is, but that is where my problem is. I really don't want to tear out the tile.
  2. Terry
    Aug 17, 2004
    When a shower arm breaks off in the wall, you may be able to chip it out using either a screwdriver, or sometimes an "easyout" tool.
    At worst, the wall may need to be cut to replace the fitting at the top.
    [​IMG]
  4. hj
    thread
    How did it get "stripped out"? If the arm just broke off a plumber can remove the remaining piece. If it broke off and you got "serious" with the thread and destroyed it, then there is no option except to open the wall and replace it.
  5. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    shower arm reapir
    if you are talking about the brass arm for the shower where the water comes out, its not a big problem.
    the best way to do it is to get yourself a sharp hack saw blade, either insert it in a tool that will hold the blade for you , or just wrap the blade with a piece of cloth . Then all you got to do is insert this in the hole .
    Cut bck and forth through the brass that is still left in the joint. After a few strokes , lok at your progress with a flashlight. Continue to cut till you basically are just about starting to chew into the fitting itself.
    try not to cut too deeply into the actual threads of the fitting
    Do this on the bottom of the fitting, then do the same thing again on the top side. Once you have accomplished this , all you really need is a tiny screwdriver, or punch and hammer to chisle and pry that brass loose.
    needle nose pliers are good to get the two pieces out too.
    If you went far enough it will come out. Then use a extra heavy amount of teflon tape on the new pipe you are putting back plus some pipe dope
    have fun.
  6. clone1008
    clone1008 New Member
    Apr 2, 2006
    Don't mean to hi-jack this thread but I had the same problem. I used the hacksaw and got the broken off threads out. However, I cut too far into the threads.
  7. Cass
    Cass Plumber
    Nov 12, 2005
    Plumbers get lots of practice doing this which makes us good at it.
  8. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    shower arm
    You are right Cass........
    If I hear him correctly, when he took the arm out, the riser moved and he can't hold it in place to connect the new arm.
    Is that right Bendal?
  9. clone1008
    Apr 2, 2006
    So, is there an easy fix to this? I was thinking maybe if I use some liquid teflon with some teflon tape this will correct the problem. Any suggestions?
  10. Cass
    Cass Plumber
    Nov 12, 2005
    All the fixes have been listed above, just pick the 1 that you want. I use a heavy duty awl that is avaliable at L***s and wedge it between the fitting and the broken arm peice with a hammer. Then pry the arm peice in. Sometimes the arm will disinigrate into small peices that can be picked out with the awl.
Similar Threads: Shower hell
Shower & Bathtub Forum & Blog Hello, Shower faucet questions. Feb 22, 2008
Shower & Bathtub Forum & Blog Re-Surface Fiberglass Tub/Shower 1piece Shell Nov 15, 2006
Shower & Bathtub Forum & Blog Swanstone Shell Shower -- any opinions? Feb 22, 2005
Shower & Bathtub Forum & Blog Cast Iron Shower drain on concrete Today at 2:58 PM
Shower & Bathtub Forum & Blog Two Shower Heads, No tub. Simple Plumbing ??? Today at 12:50 PM
