shower floor
Discussion in 'Shower & Bathtub Forum & Blog' started by handy like dad, Nov 29, 2006.
  1. handy like dad
    handy like dad New Member
    Nov 29, 2006
    nj
    I will be turning my bath/shower into a shower only and have had two different recommendations for the soon to be tiled shower floor. Mud/Rubber/cement or mud/fiberglass. I was told fiberglass moves and the tiles may become disloged but I was also told it was better for preventing leaks. Don't know which way to go.
  2. prashster
    prashster New Member
    Dec 7, 2005
    Check out johnbridge.com
    Fiberglass 'receptors' are not (generally) intended to be tiled upon. They're mostly prefinished.
    There are 2 ways to do a tiled floor:
    1) mud bed + membrane
    2) preformed shower base. Check out Kerdi from Schluter Systems. It's a 'foam' tray that gets cemented to the floor, protected with a membrane, and then tiled upon. It works in conjunction with a special drain also sold by Schluter.
    You can find out all about it at jb or Schluter's website.
    Shower floors needs to be properly sloped. You may be able to find a preformed base if your floor is one of the standard sizes. Custom or wonky shaped floors usually fare better with a mud floor.
  4. OfficeLinebacker
    OfficeLinebacker New Member
    Nov 25, 2006
    I'm all for the prefab shower bases or "receptors" as they are sometimes called. There is quite a variety in the sizes.
  5. prashster
    Dec 7, 2005
    A properly membraned floor will be as strong and leakproof as a fiberglass receptor.
    You still have wp the walls. A receptor can still leak at the wall/receptor junction. With a fully membraned shower, there is no 'seam' there. But you gotta membrane up the floor.
  6. OfficeLinebacker
    Nov 25, 2006
    At this level of leak-proof-ness, I am discriminating based on ease of installation.
  7. prashster
    Dec 7, 2005
    i hear ya!
Similar Threads: shower floor
Shower & Bathtub Forum & Blog New tub & shower enclosure - leaking on floor - shower curtain Jan 22, 2017
Shower & Bathtub Forum & Blog Shower installation over a sump pit in a concrete floor with radiant heat Jan 1, 2017
Shower & Bathtub Forum & Blog DO I NEED TO INSTALL SHOWER PAN FOR A SHOWER ON A CONCRETE FLOOR? Nov 30, 2016
Shower & Bathtub Forum & Blog Appropriate shower curb on concrete floor Sep 22, 2016
Shower & Bathtub Forum & Blog Basement Floor Drain as Shower Drain? Mar 9, 2016
