Shower Faucet Valve
Discussion in 'Shower & Bathtub Forum & Blog' started by sec1jrs, Jul 20, 2011.
  1. sec1jrs
    sec1jrs New Member
    Jul 20, 2011
    New York
    My shower is no longer giving cold water. I have read previous forum thread on how to check for debris and/or replace the cartridge. I'm a little stuck on how to proceed with to remove the cartridge. Below is a picture of my valve. What kind of valve is this? Do I remove the 4 screws to get to the cartridge? Thanks in advance for your help. IMG_04591.jpg
  2. hj
    IT is a Price Pfister pressure balanced valve. Does ANY water flow from the cold position? You remove the four screws and then pull it off, but remember HOW it was oriented or you will reinstall it wrong.
  4. sec1jrs
    sec1jrs New Member
    Jul 20, 2011
    New York
    Thanks HJ for the quick response. There is NO water flow from the cold position. I say this because, once I turn on the shower it automatically starts getting warm then hot. So in order for me to remove anything at this point, I need to remove the four screws. Got it. Yes, I have read in other threads to make sure the H/C (cartridge) are put back in the same way or else it will be wrong. Thanks for the reminder. So once I take off the four screws, I should be able to pull out the cartridge and check for debris? Thanks again.
  5. jadnashua
    Make sure you've turned the water to the house off first! But, yes, it should pull out after removing the screws. You may want to have some silicon plumber's grease to put on the rubber parts - it will make it easier to reinstall and to turn after installation. It comes in small tubs in most any plumbing supply or big box store for a few dollars.
  6. sec1jrs
    sec1jrs New Member
    Jul 20, 2011
    New York
    Resolved!!!!
    I just want to thank this forum, hj, and jadnashua. I called Price Pfister and they sent me a replacement cartridge. I received the item last night and replaced it. Cold shower is working again. Thanks!
Similar Threads: Shower Faucet
Shower & Bathtub Forum & Blog Can't find a shower faucet replacement Feb 7, 2017
Shower & Bathtub Forum & Blog Not tub / shower, but bathroom sink faucet cartridge identification Jan 13, 2017
Shower & Bathtub Forum & Blog Can anyone help identify this Shower Faucet? Oct 21, 2016
Shower & Bathtub Forum & Blog Moen Moenique, Help with shower faucet Aug 12, 2016
Shower & Bathtub Forum & Blog Mixet, Cannot Identify Old Shower Faucet Jul 27, 2016
