Shower drains slowly
Discussion in 'Shower & Bathtub Forum & Blog' started by BJH, Sep 24, 2010.
  1. BJH
    BJH New Member
    Sep 24, 2010
    SF Bay Area
    I am a homeowner who knows nothing about plumbing. I recently had two bathrooms remodeled by a reputable contractor (in business 20+ years, and carefully screened). One bathroom has a walk-in shower with a custom solid surface shower pan (using the most well-known solid-surface material). The pan was installed in the same location as the previous shower by the solid surface specialists, not the contractor. There are two problems:
    1. the pan is so flat that the shower doesn't ever dry completely. After 24 hrs, there are still small 1-2" pools of water on half of the shower (the half behind the stationary glass panel) even when the bathroom window has been open all day.
    2. The bigger problem is that when using the shower, it doesn't drain until the water level gets to be about 1+" high in the pan. When I took the first few showers, I complained to the contractor that the shower was really noisy; he said it was the PVC pipe that was there before and he didn't change anything in the drain itself. However, the drain wasn't noisy before, so I pursued it with him. His plumber wired a sponge into the drain, which helped a lot, but I requested it be removed because I was concerned about it disintegrating in the drain and having future blockage problems. This didn't seem like it was the right solution but I'm still not sure if it was removed. Then, he put a drain cover with smaller holes over the drain. It was a bubble-like plate that just has two prongs on the bottom and holes that go up the sides; the first time I took a shower I stepped on the bubble and flattened it. It's still there, but the longer the time between showers the higher the water gets before it begins to drain. Once it starts to drain, it eventually catches up with the water coming out of the faucet, but that takes several minutes. I can tell that my contractor is frustrated because he's never had this problem and wants to make it right but doesn't know how. Can someone tell me if this problem is related to the flatness of the pan, a problem with the P-Trap (whatever that is?) or something else? I would really appreciate any advice at this point! Thanks.
  2. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Your shower isn't flooding, so the the drain is not the problem. But it does sound like your custom shower pan is not sloped properly...only thing you can do is rip it out and start over.
  4. geniescience
    geniescience Homeowner
    Nov 27, 2005
    Do you know what a "level" is, BJH? Get one and post again after you have measured the slope. Web search using this word: preslope.
  5. jimbo
    jimbo Plumber
    Am I not reading it correctly? I understand him to say the water gets 1" deep in the pan. That is a drain problem
  6. jadnashua
    All horizontal surfaces in a shower should be sloped towards the drain (a nominal 1/4" per foot is a good idea). This includes the curb area where the glass walls are. You can get by with slightly less slope there, but if it is flat, or slopes the wrong way, water will pool, and never drain.
Similar Threads: Shower drains
Shower & Bathtub Forum & Blog Shower drain loud gurgling as it drains.... Jul 9, 2015
Shower & Bathtub Forum & Blog Curved Shower Drains: Installation Photos Sep 28, 2014
Shower & Bathtub Forum & Blog Shower drains in Honduras Feb 21, 2014
Shower & Bathtub Forum & Blog Testing Shower Drains for Compatibility with Wheelchair Use Nov 24, 2013
Shower & Bathtub Forum & Blog Brown ooze in shower pipes and drains Aug 5, 2012
