Shower Drain
Discussion in 'Shower & Bathtub Forum & Blog' started by ton, Nov 24, 2008.
  1. ton
    ton New Member
    Jul 3, 2008
    I have a fiberglass stall shower. When the drain plugs up and its at the slow drain stage it leaks down stairs. I unplug it and than it works fine and does not leak. Are these designed to do this. Perhaps an over flow escape route for the water or is something wrong with it like a broken seal etc. Thank you.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Somewhere there is a leak that only becomes noticable when the drain is clogged. How high does the water go before the leaking starts?
  4. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    A picture of the bottom of this shower would help quite a bit. The leak could be from a seam between the bottom and the side. Most likely, the drain needs to be either tightened or re-sealed and tightened. The extra water pressure from the standing water is causing this borderline seal to fail.
  5. ton
    ton New Member
    Jul 3, 2008
    ok I will post pictures of it from the underside and from inside the shower. As to answer your question in regards to how high the water gets. Well the base fills about an inch and than slowly drains. The outside rim of the drain would be exposed to water. Thank you.
Similar Threads: Shower Drain
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Remodel: what type of drain to use in shower receptor Jan 12, 2017
