Shower Drain
Discussion in 'Shower & Bathtub Forum & Blog' started by NewDIYer, Feb 18, 2008.
  1. NewDIYer
    NewDIYer New Member
    Feb 18, 2008
    I am remodeling my old bathroom (1964). I have removed the concrete shower pan and realigning the shower drain so that it will be center with the new shower pan. I have got it moved and centered but it seems like the p-trap has a lot of water sitting in the trap. It does not seem like it is washing out. My question is how much water should be sitting in the p-trap?
  2. jadnashua
    The trap water level will sit at the level of the bottom of the outlet arm. If you are tiling this, suggest you check out www.johnbridge.com if you haven't already.
Similar Threads: Shower Drain
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Remodel: what type of drain to use in shower receptor Jan 12, 2017
