Bid19123
I have just started the demolition work to replace a nasty old tub with a walk in shower. Found some surprises under the tub. For some reason it had been packed in with old clothes; not nice. Also the tub was to small for the alcove space so the walls at the lower 2 feet had been mortared out at 45 degrees. Biggest surprise was the drain; it sits in a sand filled hole. After removing some of the sand to expose the pipe I came across a black cable which I think may be an electrical line; I am a little scared to continue. The main problem is the drain is only 1.5 inches and I stupidly purchased a 2 inch drain for the shower. What are the available options to resolve this? The drain pipe is under a concrete foundation so I cant replace it to 2 inch pipe. Can I reduce the drain I purchased down to 1.5 inches. I am scared this may cause a problem later down the line. One last question; How is the hot and cold water pipe normally run in a concrete block house. I hoped it would run under the floor from the adjacent bathroom but I cant find any sign of it
