Shower drain PVC pipe coating?
Discussion in 'Shower & Bathtub Forum & Blog' started by WorthFlorida, Jun 10, 2011.
  1. WorthFlorida
    WorthFlorida USCG escorting cruise ship leaving Port Everglades
    Oct 28, 2009
    Retired
    Orlando, Florida
    This is the second home I've seen this. Removing the shower drain cover to clean soap scum and hair, there seems to be a very thin rubber type coating from the drain cover to maybe four to six inches into the pipe. It appears to mask the white pipe so the drain looks black and therefore you cannot see the dirty white pipe. What is this stuff and its use? Can it be bought to re-coat the drain?
  2. WorthFlorida
    Oct 28, 2009
    Retired
    Orlando, Florida
    I talked to a plumber this week and never heard of it and I'm starting to realize that it just slime and mold. A few years ago I remodeled the bathroom and I did clean the drain quite well. What happens is as soap and body oils go down the drain, it starts to coat the top part of the drain flange and pipe. Over time this scum starts to mold up and lines the pipe. It is so even that you swear it was sprayed on. I saw the same thing at my sons house and the house was maybe a year old at the time. He stopped using it because it looked like it was a seal coating and there could be a leak. If anyone that has a walk in shower you should pull the drain cover anyway to clean it out because a lot of hair does build up and it is a source of odors.
Similar Threads: Shower drain
Shower & Bathtub Forum & Blog Cast Iron Shower drain on concrete Yesterday at 2:58 PM
Shower & Bathtub Forum & Blog Odd Shower Drain Rough In Mar 5, 2017
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Feb 25, 2017
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
