Shower Drain & Plumbers Putty
Discussion in 'Shower & Bathtub Forum & Blog' started by Mike from Brier, Feb 15, 2009.
  1. Mike from Brier
    Mike from Brier New Member
    Jul 4, 2005
    Brier, WA
    Howdy all--
    New shower receptor and wall surround going in (Sterling Vikrell). Old shower pan had the drain flange/fitting installed with silicone caulk between the flange face and pan.
    We're using the old flange on the new receptor: Is it acceptable to scrape off the caulk and use plumbers putty on the mating surface, or should it be silicone caulk instead?
  2. thebigsee
    thebigsee DIY Member
    Sep 24, 2009
    Southern California
    This is an old post, but just want to point out that I was going to use plumbers putty but then saw that both Oatey and Sioux Chief recommend silicone for their drain installs with preformed showers. I used silicone and am very glad I did. It will be a pain if I ever need to remove it, but if that's the case, it's time to install a new shower I think!
Similar Threads: Shower Drain
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Remodel: what type of drain to use in shower receptor Jan 12, 2017
