Shower Drain Location
Discussion in 'Shower & Bathtub Forum & Blog' started by wyo1661, Mar 9, 2005.
  1. wyo1661
    wyo1661 New Member
    Mar 9, 2005
    My shower drain rough-in is 7" from the foundation wall. After I frame the wall, it will be even closer to the finished wall. Am I limited to a tub or are their shower pans with the drain at one end (as opposed to the center like most I have seen).
    Thanks in advance for any guidance.
  2. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    There are many showers that fit into a bathtub space having either a right or left hand drain like a bathtub. All hope is not lost! :D
    Good luck
  4. jadnashua
    First, make sure it was plumbed for a shower - it needs to be a 2" drain pipe. It is best to have the drain in the center, but it can work elsewhere. The problem is, that you need 1/4" per foot slope of the floor, and if it is not in the middle, it is quite steep on the short side and looks weird. My unprofessional opinion.
  5. wyo1661
    wyo1661 New Member
    Mar 9, 2005
    Good info guys. Thanks. I am certain it is for a shower as its a 2". I am concerned that I cannot get a wall between the bowl and the shower as I would breach the 15" minimum barrier. If I go with a tub, the barrier is not such an issue.
    One more question. Currently, I am using 2x4 studs on both the front (being where the shower head will go) and side (against the concrete foundation walls). I think I need to use 2x4 framing for the front as that is what the hot and cold pipes need to mount to as well as the shower head. But against the back, is it normal or OK to go with something less than 2x4's? Perhaps furring strips? This would allow me to gain an inch or two away from the toilet.
    All the contractor had to do was move the toilet over about 6 inches and problem solved. :)
    Thanks again for your input.
  6. jadnashua
    I'd bite the bullet, break the floor, move the toilet over where it isn't a problem and center the shower drain. In the long run, you'll be much happier. While a messy job, it isn't all that hard.
  7. hj
    drain
    If I had done that job, I would have installed a 2" drain at that location for a bathtub, or a 2" drain in the "center" for a shower. Your terms "front" and "side" may mean different things to us than they do to you, but you can use anything you want on the concrete wall to furr it out.
Similar Threads: Shower Drain
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Remodel: what type of drain to use in shower receptor Jan 12, 2017
