Shower Drain Leaking from Unsupported Shower Base
Discussion in 'Shower & Bathtub Forum & Blog' started by msche398, Jul 9, 2013.
  1. msche398
    msche398 New Member
    Jul 9, 2013
    Greenville, South Carolina
    I have a single-piece fiberglass shower that is leaking from the drain. The cause is that the base is not supported well and the bottom flexes, causing the drain to loosen. It has been tightened several times but seems to keep coming loose.
    Any suggestions on how to adequately support the shower so that the bottom doesn't flex? It is located on a 2nd floor.
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    There are many ways to support this section of your shower. You would need access from below. Can you gain access and then post a couple of pictures?
    With a few simple Strong Tie Brackets and some common 2"x4" stock you would be able to support the area around the drain.
    We love working with spray foam products and you might weight the drain area with a garbage can of water 15 Gallons or so should give you a 120 pound brace and then spray foam the area. This would work only for smaller gaps so before jumping in get the hole opened up and send us some pictures.
    Do you know how to post pictures here on Terry's page?
    JW
  4. Terry
    Aug 17, 2004
    Some of those were installed with putty.
    You may need to remove the old drain and reinstall a new one with Silicone.
    At that time you can add something below the pan to try to prevent the movement.
  5. msche398
    msche398 New Member
    Jul 9, 2013
    Ok. I will first work on opening up the ceiling below and getting some pictures.
Similar Threads: Shower Drain
Shower & Bathtub Forum & Blog Cast Iron Shower drain on concrete Mar 22, 2017
Shower & Bathtub Forum & Blog Odd Shower Drain Rough In Mar 5, 2017
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Feb 25, 2017
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
