Shower drain leak help needed.
Discussion in 'Shower & Bathtub Forum & Blog' started by tjkruts, Jan 10, 2008.
  1. tjkruts
    tjkruts New Member
    Jan 10, 2008
    I have a fiberglass shower (upstairs) and recently the drain started leaking. (A drip from the ceiling below.) I would think that it would have to do with the seal to the shower floor? Are there any other reasons? Is this a fix requiring me to go through the ceiling below or can it be sealed from above.
  2. Terry
    Aug 17, 2004
    Most of the time, it's the putty drying out on the drain.
    Normal repair is to replace the drain, using Silicone this time from the underside. Yes, the ceiling will be cut out to do this.
    If not the drain, it could be someone showering with the door open, ( Yes, this really happens, they sometimes don't admit it until after I've cut holes in their home. )
    Or one time, it was a broken shower arm. I discovered that one in a third floor apartment, they knew the shower head was dangling there, but didn't bother to tell anyone.
    Or it could be the seal around the shower faucet pie pan.
    See..........It's easy!
Similar Threads: Shower drain
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Saturday at 4:17 PM
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
