Hi,
I am about to start a condo remodel in Colorado on a building built in 1981. I have not remodeled a bath in 10 years so I have done a fair amount of research and have decided to use a Kerdi shower system. Had a friend just use it and was super easy.
I have three baths being remodeled. Two baths are replacing tub/showers with walk-in showers. I was looking at using the Kerdi Shower Kit because it sounds as if the Kerdi drain will fit right over the existing drain. That was until I spoke with the building maintenance man who informed me there was no slab penetration and the original tub drains over to the wall. Sounds like the trap is in the wall and not below the tub. Also found out the toilet has a wall discharge, so my toilet budget went up a bit too.
So, I am trying to research how to build my new shower and how this drain will work. I'm pretty sure the Kerdi Shower pan with the offset drain shower will not work cause it needs floor penetration. I like the look of the Kerdi Line linear shower drain, but looks like it needs a trough under it. Also see that http://www.tileredi.com has a linear drain, but looks like it may go out through he floor too.
Any help and advice will be greatly appreciated.
Thom
Thom
