Shower Drain Horizontal Before Trap?
Discussion in 'Shower & Bathtub Forum & Blog' started by Wojocad, Apr 12, 2011.
  1. Wojocad
    Wojocad New Member
    Apr 12, 2011
    Astoria, Oregon
    I'm thinking of adding an upstairs bath above a rather ornate living room ceiling that I'd rather not cut into. Is it OK to raise the level of the upstairs fiberglass shower pan (maybe 6 inches) and then have the drain line from the shower pan run horizontally at a minimum slope for maybe 3 feet before adding a trap? The idea is to not cut into the existing upstairs floor deck until the shower drain line runs over an area of attic that I don't mind cutting into. I'd have access to check the trap there via a clean-out cap instead of right at the shower drain.
  2. jimbo
    jimbo Plumber
    Raised showers or toilets invite some really nasty comments from Mike Holmes about "do it right"
  4. jadnashua
    The longer the pipe between the drain opening and the trap means the more of the pipe that can accumulate stuff like sludge, hair, dead skin, soap scum, etc. The trap is what isolates the room from the rest of the sewer. After awhile, you probably won't like a long trap arm!
    You might consider a trench drain that you could install over one end that is where you could install the trap. A little more involved, but in some ways, easier since you only need one slope rather than a 'funnel', it's a single sloped plane.
Similar Threads: Shower Drain
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Saturday at 4:17 PM
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
