Shower drain grates
Discussion in 'Shower & Bathtub Forum & Blog' started by justin76, Oct 4, 2011.
  1. justin76
    justin76 New Member
    Oct 4, 2011
    Ontario Canada
    Recently I installed a shower drain grate/basket to prevent hair from clogging my drain pipes. My wife has complained ever since as her hair now plugs the grate causing her to have to remove the hair several times during her shower. Prioir to the grate the pipes would plug off causing me to have to plunger the drain on a regular basis. She thinks I should remove the grate as not only is it causing her to clean the hair out while she's showering she also says it causes soap scum to build up as the water tends to stand when she gets out. I've told her to ensure she cleans the grate before, during and after she is done showering but she seems to think this is to much. Does anybody have advice on different grates/baskets mine sits in the drain hole.
  2. hj
    Obviously you have a hair problem if it clogs while she is using the shower. Changing, or removing, the grate is not going to make it go away. All it will do is "move it" somewhere else, which is why your drain line clogged when you did not have the strainer. The only solution for your problem, if you cannot live with it is to tell her "Bald is beautiful".
  4. justin76
    justin76 New Member
    Oct 4, 2011
    Ontario Canada
    Thanks now I can show her you reply & the that its a fact the grate is the better option over letting the pipes clog up!!:D I think a shaved head and a wig could be the other option!
  5. jadnashua
    Maybe if she brushed her hair before she showered...there'd be less to fall out while showering.
Similar Threads: Shower drain
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Yesterday at 4:17 PM
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
