Shower Drain Assembly is rusting
Discussion in 'Shower & Bathtub Forum & Blog' started by robertwcaldwell, Aug 4, 2009.
  1. robertwcaldwell
    robertwcaldwell New Member
    Aug 4, 2009
    General Contarctor
    San Carlos, CA
    I installed a new shower with a presloped mortar bed, a leak-tested membrane and a steel drain assembly. My client removed the grate to flush out the line when the existing drain pipe backed up. When he resolved that issue he noticed that the painted steel drain assembly already showed rust after a matter of weeks. Is there any cause for concern?
Similar Threads: Shower Drain
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Remodel: what type of drain to use in shower receptor Jan 12, 2017
