Shower door rail has openings INSIDE the shower? Ruining caulking.
TxBuckeye
San Antonio, Texas
So I posted earlier about my caulking failing. Now I am having the issue again in other places. So I was tearing out the old caulking to redo it yet again and there was a LOT of water behind the caulking. So I cleaned it all out and let it sit to get good and dry. I went back up and had a lot of water again. I dried it with a towel again, went back, and had a lot of water again! After several rounds of this, I noted this:
http://imgur.com/OGA5fON
It seems the water is all inside the base of my door and is just running back in to the area where I pulled out the caulking. These are indeed openings. The rail seems hollow, so it seems these openings are just letting the water collect and drain in behind my caulking, and that is what is causing it to rot out and my shower to leak. Is this right? Should these openings be there on the inside of my shower? Seems like these should be capped off or something?
TxBuckeye
San Antonio, Texas
Should that water be able to run out the end and get in behind the caulking? Because honestly, that seems to be what is happening.All the water I keep cleaning up and reappearing is in that corner where that frame meets the wall. Coincidence? Should I be looking for plumbing leaks or something? The shower is upstairs and we haven't seen any signs of leaks on the ceiling downstairs or anything.
Montreal, Canada
I don't know what your DIY skillset is like, whther you followed the manufacturers installation instructions.
We'd need to see a pdf or scan of the install literature.
We'd need to see pics of your work every step of the way.
Those holes on the bottom are weep holes and MUST be left exposed.
You have to seal the ends with caulking. It should have been done when the bottom rail was installed between the side rails, (when it was bedded to the sill with caulking).
