shower divertor valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pawpace, Aug 7, 2009.
  1. pawpace
    pawpace New Member
    Jun 15, 2009
    I have a shower with an older one handle valve for off and on and hot/cold. It is a Moen (I believe) with the plastic ball inside with the two rubber caps and springs. I am not getting water pressure ( only a small trickle) to the shower head so I replaced the springs and caps. The ball looked like it was in good shape with no obstructions inside so it was not replaced. The rebuild did not do any good. I am getting good water pressure to the valve but cannot get the pressure to the shower head.
    This shower is in the basement and does not get a lot of use. Thinking there might be an obstruction, I have tried to run a wire from the valve to the head but too much of a bend for the wire to make it all the way thru.
    Any suggestions on what the problem might be?
    Thanks
    Mike
  2. jimbo
    jimbo Plumber
    Not Moen. Sounds like Delta. In any event, first suspect is the shower head itself. Remove it and see if water flows well out the arm. If so, the inlet screens and/or internals are clogged on the head.
  4. pawpace
    pawpace New Member
    Jun 15, 2009
    Yep, already tried that. Shower head is not clogged.
    Thanks
    Mike
Similar Threads: shower divertor
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Wednesday at 10:36 PM
Plumbing Forum, Professional & DIY Advice Shower venting details/ dry run Wednesday at 7:14 PM
Plumbing Forum, Professional & DIY Advice Broke my cold water stem for my shower. Options? Tuesday at 10:06 PM
Plumbing Forum, Professional & DIY Advice New shower / check valve question Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Sewage ejector air coming up shower drain Feb 7, 2017
