Shower Diverter Handle Stuck Open
Discussion in 'Shower & Bathtub Forum & Blog' started by filthee, Feb 10, 2008.
  1. filthee
    filthee New Member
    May 14, 2007
    Hello all. My wife just informed me that the lever on her shower faucet that diverts water from the bath faucet to the shower head has been stuck for the past 3 months. :confused: It's the kind of lever that you pull/push up or down to alternate between shower and bath.
    It seems like it's fused rock solid. I mean there's no play at all. I screwed the whole faucet assembly loose so I could look into the mouth of the faucet. There is some mineral buildup there. Could that be all it is?
    If not, what's my next step?
    Thanks. :eek:
  2. jadnashua
    There are thousands of models out there...it would help with the brand and model, but if that isn't possible, post a picture.
  4. filthee
    filthee New Member
    May 14, 2007
    Here you go. I hope this helps. Thanks!
    [​IMG]
  5. hj
    diverter
    CHANGE the diverter. They are so cheap it is not worth my time, or yours, to try to repair it.
  6. filthee
    filthee New Member
    May 14, 2007
    Thanks guys. I'll give it a shot.
  7. jadnashua
    You can just see the set screw in that slot underneath the spout. Loosen it up and the spout should pull off (didn't notice if there was any caulk - that might need cutting). IF the setscrew wasn't too tight, sliding a new one on is easy. If it was tight, sometimes the seal can be problematic if the pipe is no longer round. You may want to remove any burr if there is one from the screw so you don't damage the O-ring in the new spout.
Similar Threads: Shower Diverter
Shower & Bathtub Forum & Blog help finding shower head diverter Jan 28, 2017
Shower & Bathtub Forum & Blog Upgrade Manufactured Home 2 Handle Valve with Bath Shower spout and diverter Jan 11, 2017
Shower & Bathtub Forum & Blog Piping and a 3 way diverter in shower Nov 15, 2016
Shower & Bathtub Forum & Blog Help identifying shower diverter stem Sep 23, 2016
Shower & Bathtub Forum & Blog Water comes out from shower diverter spout May 23, 2016
