Shower Curb / Custom Shower Questions
Discussion in 'Shower & Bathtub Forum & Blog' started by n0teye, Aug 29, 2011.
  1. n0teye
    n0teye New Member
    Aug 29, 2011
    California
    1. When building a shower curb on a concrete slab I have opted to go the brick route as opposed to the 2x4 route. I understand how to affix the bricks to the slab, however I haven't been able to find a solid answer on what I am supposed to use to affix the vinyl water barrier to the outside of the curb (bricks) as well as the metal lathe used to form the curb over top of the vinyl.
    2. Also on a concrete subfloor, do I need to lay down tar paper / metal lathe to give the pre-slope something to grab onto? If so, what is the proper way to secure these two items to the concrete? I've also read that you can just use thinset to have the existing slab bond to the pre-slope.
    Appreciate the help in advance!
  2. jadnashua
    Well, on question 2, either put down some thinset or make a slurry of portland cement before you throw down the deckmud. Make sure you cover it before it skins over. On a slab, you want it bonded, and either of those will bond it in place. If it was on a wooden slab, then you'd want something to prevent the wooden deck from sucking the moisture out of the deckmud before it had a chance to cure...not the case on a slab.
    If you overbend the lath for the curb, it will act like a spring clamp. Be careful not to tear the liner when you put it over the curb. Then, you cover it with a sticky brick mortar. A good place for reference material on shower building and anything tiled is www.johnbridge.com. Look in their 'Liberry' section.
  4. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Building a shower in the basement.
    Post(s) deleted by John Whipple
  5. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Nobel Installation Video
Similar Threads: Shower Curb
Shower & Bathtub Forum & Blog Appropriate shower curb on concrete floor Sep 22, 2016
Shower & Bathtub Forum & Blog Shower Tray for Curbless Shower & Linear Drain May 12, 2016
Shower & Bathtub Forum & Blog Curbless Shower Question May 2, 2016
Shower & Bathtub Forum & Blog Shower 'ceiling 'curb' Pros/Cons? Aug 27, 2015
Shower & Bathtub Forum & Blog How Do You build the floor in a Curbless Shower Stall? Aug 3, 2015
