Shower base movement
Discussion in 'Shower & Bathtub Forum & Blog' started by Jim1327, Feb 24, 2008.
  1. Jim1327
    Jim1327 Tool and Diemaker
    Feb 24, 2008
    Tool and Diemaker
    I installed a new fiberglass shower in our second floor master bath. I installed the base as per instructions by placing 6 or 8 blobs of thinset morter and pushing the base down on the morter. Everything was fine for about 6 months then I noticed the base would move a little when you stepped on it and got a little worse over the next few months. It has been over a year since I installed it and I still have movement. I am afraid this will eventually cause the development cracks in the base. I may be able to access it thru the back wall or making a hole in the cealing under it by the drain. Does anyone have any suggestions how to fix this problem?
  2. Nate R
    Nate R Member
    Jan 11, 2007
    I perform R&D testiing at small engine manuf.
    Milwaukee, WI
    I've heard of filling voids under fiberglass tubs and shower bases by going from underneath and filling the void w/ expanding foam. Some say the best answer is to rip it out and do it again.
    BTW: Not 20 minutes ago I just did the same thing for our new fiberglass tub. Looks like the mortar wasn't quite thick enough in one spot. The rest of the tub is solid besides the one area I was feeling movement. I was able to drill from underneath. First through the subfloor. Then, w/ a masonry bit I went through the mortar w/ a depth stop so I didn't go too far. (Since I knew approx how thick the mortar was.) Popped through the mortar. Shot foam in and filled it up. Curing now, we'll see how it goes.
  4. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    If your mix of thin set mortar was too wet, it may have spread too easily and sunk more than you want it to. in cases that I have done, I try to use a cement sandmix with a dryer consitancy
  5. Jim1327
    Feb 24, 2008
    Tool and Diemaker
    What kind of foam did you use?
  6. Nate R
    Nate R Member
    Jan 11, 2007
    Milwaukee, WI
    Great Stuff. I used the large gap/crack filler (Black can) because it's what I had.
  7. jadnashua
    If you try foam, you want to use the low-expansion stuff that stays flexible, otherwise, you'll crush the stuff into a powder after awhile.
    Thinset is not designed to be used in a layer greater than about 1/4" or so. If it is too thick, it can take awhile to cure, so if you tread on the base too soon, you'd mush it out of the way, and then have no support. Deck mud, or a sand mix gets pretty dense fairly quickly, but neither should really be walked on for 12-24 hours.
Similar Threads: Shower base
Shower & Bathtub Forum & Blog Shower Leak to basement... Feb 10, 2017
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Improve Shower Base Support Dec 20, 2016
Shower & Bathtub Forum & Blog Shower base install - cbu before or after? Nov 18, 2016
Shower & Bathtub Forum & Blog 60"x40" shower base/pan Sep 12, 2016
