Shower and Bath Same Wall
Discussion in 'Shower & Bathtub Forum & Blog' started by joejazz, Mar 15, 2013.
  1. joejazz
    joejazz New Member
    Mar 15, 2013
    Clinton Township Mi
    I have a shower and a bath tub/shower that are on opposite sides of a 2x4 wall. The old shower valve (vintage 1970) that was leaking was small compared to the shower valves I've seen at Lowes and HD. I am eventually going to replace the bath tub/shower as well. Trying to figure out how to plumb and install a new valves and shower heads. Been looking at Delta shower valves and kits at Lowes and HD and it seems like will run into interference between the pipes and strigers. Any ideas? Pictures or drawings would be helpful.
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Plumber can weave some magic. There is so many ways to pipe these showers.
    We have built many back to back showers. It's not hard it's just cramped.
    JW
  4. Terry
    Aug 17, 2004
    Normally the shower valve is set at about 48" and the tub at 28" to 35"
    You should have plenty of room.
    Delta is a good one to use.
  5. jadnashua
    Also, to make things easier, SOME of the valves can accommodate the hot/cold inlets being swapped so you don't need to cross the piping when you have two valves in the same wall. On some, you can insert the cartridge 180-degrees from normal, and it works, on others, you may need a special cartridge. If you go to the Delta website on a valve you like, they do have the installation instructions, and it normally will tell you how to do this, if it is possible. Otherwise, you need to route the piping to the 'proper' side of the valve.
Similar Threads: Shower Bath
Shower & Bathtub Forum & Blog Bathtub/shower enclosure product choices Jan 26, 2017
Shower & Bathtub Forum & Blog Not tub / shower, but bathroom sink faucet cartridge identification Jan 13, 2017
Shower & Bathtub Forum & Blog Upgrade Manufactured Home 2 Handle Valve with Bath Shower spout and diverter Jan 11, 2017
Shower & Bathtub Forum & Blog Bathroom Shower Drain Aug 1, 2016
Shower & Bathtub Forum & Blog Installing Kohler Rite-Temp Bath & Shower Valve K304 + Mastershower 2 or 3-way Transfer Valve K728 Jun 5, 2016
