Should mains be 110v or 120v?
Discussion in 'Electrical Forum discussion & Blog' started by dgold, Jul 25, 2007.
  1. dgold
    dgold Product R&D
    Dec 6, 2006
    Product R&D - Swimming Pool Industry
    Carlsbad, CA
    This question is purely for curiosity's sake...
    I've searched all over the internet, but get conflicting information. Is US mains power supposed to be 110v (220v if pulling from both sides), or 120v (240v if pulling from both sides).
    I remember hearing somewhere that it's really supposed to be 110v, but there's conflicting info all over the place. I doubt it really matters for most appliances, but I'm very curious.
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    North Carolina
    220.5 Calculations.
    (A) Voltages. Unless other voltages are specified, for purposes of calculating branch-circuit and feeder loads, nominal system voltages of 120, 120/240, 208Y/120, 240, 347, 480Y/277, 480, 600Y/347, and 600 volts shall be used.
    Table 430.248 Full-Load Currents in Amperes, Single-Phase Alternating-Current Motors
    The following values of full-load currents are for motors running at usual speeds and motors with normal torque characteristics. The voltages listed are rated motor voltages. The currents listed shall be permitted for system voltage ranges of 110 to 120 and 220 to 240 volts.
    to answer your question one would have to say
  4. jadnashua
    My local service averages 118vac. That gives them a little wiggle room if the load increases. Most devices in the US are designed for 110-120vac operation, and many, if designed for international operations can operate with a much wider range (I've got one TV that is spec'ed for 80-250vac input!).
    As an aside, you can buy lighbulbs spec'ed at 130vac. They won't be as bright, but they will last a very long time compared to 120vac rated bulbs.
Similar Threads: Should mains
Electrical Forum discussion & Blog What wire gauge should I use Dec 30, 2015
Electrical Forum discussion & Blog Shouldn't Light Fixtures Have Bare Grounding Wire Connected? Dec 11, 2012
Electrical Forum discussion & Blog This is why no one should ever get cocky when someone explains electrical Jul 5, 2012
Electrical Forum discussion & Blog Looks like we should wire with "pipe" ! Jun 17, 2012
Electrical Forum discussion & Blog Old house, 100A fusebox, should we replace w. breakers? Jan 12, 2012
