I need to restart my quest in a different direction. Since the pump I thought I had ordered, was not. I need to re-evaluate the pump. As noted much earlier in the thread, the 25GB is really to large. My target of 25GPM came from the original pump I am trying to replace. It was rated at 25GPM @ 60psi but I don't think it was ever doing that. Based on how long it would run when refilling the pressure tanks. And the reason for the size is lost in the cobwebs of my mind. But basically I was probably thinking about possible fire suppression and irrigation. Probably a swag.
So back to square one.
What capacity pump do you guys recommend. Normal residential use + watering a fair amount of garden + maybe worrying about fire. And the garden does not have to be watered all at one time. So let us say 2 watering hoses + household use.
I have gone back to the Goulds curves and have a number of potential alternatives. The curves are in the PDF
B5 33GB 5GB, 7GB, 10GB, 18GB, 25GB, 33GB HIGH PRESSURE MULTI-STAGE BOOSTER PUMP at the link I provided earlier.
It would appear that an 18GB10 would be fine. It would meet my original 25GPM target. I was under extreme pressure (pun NOT intended) at the time to get something into the house before we had to leave on a trip. And the plants would die. I did not do a very good job of it. I probably just saw 25GPM and only looked at those curves. But, since I am rethinking it, a still smaller unit would also seem to be a decent idea.
Moving down the sizes, the 10GB07 would provide 16GPM through the 40-60 psi operating range. That is perhaps a more rational alternative. A 7GB07 would give about 10 GPM.
Can you guys please make some recommendations.; 25, 16, 10, or other.
