Should I try to clean the A/C coils myself?
Discussion in 'HVAC Heating & Cooling' started by riker1384, Oct 28, 2008.
  1. riker1384
    riker1384 New Member
    Sep 19, 2006
    Virginia
    The coils on the indoor part of our air-conditioning/heat-pump system are dirty. Is this something I should try myself? I'm any sort of professional. Some sites say I could do it myself, some say it should be left to experts.
  2. jadnashua
    If you do it yourself, you may want to invest in a fin comb to straighten any bent fins.
  4. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    A garden hose works well, but you have to make sure to shoot straight in or it will bend fins.
  5. burleymike
    burleymike New Member
    Nov 4, 2008
    Idaho
    I usually use a pump up sprayer with some coil cleaner. You will be just fine with just plain water. If you don't have a pump sprayer you can use the garden hose just dont hit it with a lot of water. You don't want to get the blower or anything else wet. Also make sure your condensate drain does not plug up with the crud.
  6. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    This is an inside evaporator guys, not the outside condenser. A garden house will create a wet mess.
    Most manufacturer's will tell you what type of brush to use to clean the coils dry. If you can't locate the manual that came with the unit then Google "condenser brush" and looking at your unit and accessibility figure out which type will work best for you. Keep the shop vac going to catch the dust because it's very fine and irritating.
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I use the same method Burley Mike described.
    Garden House?
    I'll assume that you added extra letters to "hose"
    Maybe an engineer would make a mess with a hose, but, most of us would know to be careful and make sure the condensate drain is not plugged.
  8. Southern Man
    Jun 27, 2008
    North Carolina
    Yes I meant garden hose, not house. A garden hose would create quite a mess inside a residential house, but would probably be manageable inside a garden house. Although I have yet to see a garden house with AC.
    I appreciate your exactness kind sir. :)
Similar Threads: Should clean
HVAC Heating & Cooling Adding HVAC register - should be simple...but maybe it isn't. Dec 14, 2015
HVAC Heating & Cooling Heating Basement & Up satires Should you separate heating systems Sep 1, 2014
HVAC Heating & Cooling Mitsubishi Mini split -should I worry more about enough heat or short cycling? Dec 6, 2013
HVAC Heating & Cooling Should I remove a radiator Dec 4, 2012
HVAC Heating & Cooling Which boiler should I choose? Burderus GB 142 or HTP Elite FT 80? Apr 18, 2012
