Should I seal shower faucet between the escutcheon and the sleeve?
Discussion in 'Shower & Bathtub Forum & Blog' started by gthawkster, Jun 29, 2013.
  1. gthawkster
    gthawkster New Member
    Jun 29, 2013
    Kansas
    I repaired a leaky Delta single handle faucet which had a foam seal in the inside of the escutcheon but also a foam ring (1-7/8 ID) that fit around the sleeve behind the escutcheon. This foam ring was damaged. I plan to run a caulking around the outside of the escutcheon but I was wondering if I need to seal between the escutcheon and the sleeve since the small foam ring is gone. Thanks for your help.
  2. hj
    I do not. But, then, I don't even remove the escutcheon since the valve is repairable without doing it. Sometimes getting the escutcheon bolts aligned is problem when the valve is set back into the wall almost at the maximum depth.
  4. gthawkster
    Jun 29, 2013
    Kansas
    Thanks for the reply. What keeps water from seeping in between the escutcheon and the metal sleeve?
Similar Threads: Should seal
Shower & Bathtub Forum & Blog Should I seal or not Sep 30, 2013
Shower & Bathtub Forum & Blog Bathtub Mortar - Should I be worried? Feb 13, 2017
Shower & Bathtub Forum & Blog Should I DIY a Shower Pan and Tile? Jan 27, 2017
Shower & Bathtub Forum & Blog Should I reuse my old Moentrol valve? Jul 1, 2016
Shower & Bathtub Forum & Blog What kind of paint/primer should I use in a shower/bath room? Nov 12, 2014
