Should I install a whole house filter before water softner?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by polocash, Mar 28, 2005.
  1. polocash
    polocash New Member
    Mar 27, 2005
    Will this help prolong the life of a water softner? Are there other benefits? I already have 2 stage filters at sink and frig. for ice, cooking and drinking water.
    Rick
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    hole house filter
    if you are on a well, it might be a nice thing to do....
    wouild work like a sand filter and keep the sediment out of the unit
    if you are on city water, a pressure reduceing valve would be a better choice
    if your water is above 95 psi...during the day.
  4. Gary Slusser
    Retired
    With certain brands of control valves yes, they can't handle dirt very well and some simply gag on it but... Clack and Fleck controls have no problem with very dirty discolored water. We use them on very dirty water when we need a turbidity or heavy iron filter. On a softener, if the water is that dirty, you need a backwashed filter in front of the softener but I suggest not using a softener with a control valve that can't handle the dirt in the vast majority of well or city waters. Also, most dirt will be backwashed out of a softener, so those softeners that suggest using a prefilter.... IMO they are not the right choice for that water or the clerk etc. is simply trying to sell you more than you need.
    Using a prefilter when not needed also causes a softener problems due to the pressure loss the filter causes.
    Gary
    Quality Water Asscoiates
Similar Threads: Should install
Plumbing Forum, Professional & DIY Advice Should I install Metal or Plastic sink drain?? Oct 7, 2010
Plumbing Forum, Professional & DIY Advice Should I install a cleanout below toilet? Sep 28, 2008
Plumbing Forum, Professional & DIY Advice Should I install a cleanout for new toilet drain installation? Sep 27, 2008
Plumbing Forum, Professional & DIY Advice How should this humidifier overflow be plumbed? (pics) Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
