Should I install a cleanout for new toilet drain installation?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by redgreen, Sep 27, 2008.
  1. redgreen
    redgreen New Member
    May 24, 2008
    Canada
    The drain coming from the main floor toilet comes through the basement ceiling and I was going to just add a 90, then a 5 foot horizontal run before it will enter a san-tee that I will add to an existing vertical stack which goes to a second story bath.
    Instead of the 90 can I install a wye on it's back, add a 45 to connect the toilet, the downstream of the wye will connect to my 5 foot run and on the other end of the wye I was going to extend it a foot longer and add a cleanout. Is adding a cleanout as I described a good idea and is it allowed as I described?
    Thanks.
  2. hj
    piping
    NOTHING about what you describe is a good idea, nor is it legal or proper. Or rather maybe the cleanout is the only part of it that MIGHT be a good idea.
Similar Threads: Should install
Plumbing Forum, Professional & DIY Advice Should I install Metal or Plastic sink drain?? Oct 7, 2010
Plumbing Forum, Professional & DIY Advice Should I install a cleanout below toilet? Sep 28, 2008
Plumbing Forum, Professional & DIY Advice Should I install a whole house filter before water softner? Mar 28, 2005
Plumbing Forum, Professional & DIY Advice How should this humidifier overflow be plumbed? (pics) Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
