Should I ad an expansion tank?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tjbaudio, Dec 18, 2005.
  1. tjbaudio
    tjbaudio Sound and Light Suppervisor for a School District
    Dec 6, 2005
    sound and light suppervisor for a school district
    Wisconsin
    With all of the other pluming I am doing right now it would be an easy time to add an expansion tank. The question is do I need one? Should I add one just because? I got a new water meter a few months ago and I have a 40 gallon gas HWH that is about 2 years old. The city is doing lots of work on the water plant and water lines in the streets. I could also add a permanent pressure gage. Any thoughts on this?
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Do you have a PRV on your incoming water line? If so, the tank is warranted.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I just went through this, so maybe this will help. Get a pressure gauge and attach it to a hot water faucet. Watch what happens when the heater is in operation. My heat is gas, so it was quite simple to know when it began to heat. If yours is electric, run another hot water tap and drain the hot water down. If the pressure remains constant when the heater is operating, you don't need an expansion tank. If it rises, you do. Of course, it was already pointed out that if you have a PRV, you need the expansion tank because that creates a closed system. The new meter the water department put in may have a backflow prevention valve which also would cause a closed system. The pressure gauge will tell the tale very quickly.
Similar Threads: Should expansion
Plumbing Forum, Professional & DIY Advice How should this humidifier overflow be plumbed? (pics) Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
Plumbing Forum, Professional & DIY Advice Older septic system runs fuller than it should; how to clear out sediment from lines? Dec 7, 2016
Plumbing Forum, Professional & DIY Advice Surface Rust / Cracking at Kitchen Sink hole - Should I repair it or ignore it? Oct 22, 2016
Plumbing Forum, Professional & DIY Advice Valve Stem Leak. Should I be worried? Sep 22, 2016
