Should hot and cold pex pipes be separated? Or can they touch?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ironspider, Mar 5, 2010.
  1. ironspider
    ironspider Member
    Jul 26, 2008
    Michigan
    Greetings all,
    I am installing some pex-a piping and I've got several lines to run through a room about 30'. My plan is to run these pipes through a PVC conduit just to keep them neatly contained and organized.
    My question though is whether pex pipe must be kept in a state where the hot and cold don't touch? Or is pex constructed such that if a hot pex pipe was touching a cold pex pipe they wouldn't affect each other enough to be noticeable in any way at the fixtures?
    The reason I ask is because I'd like to run ONE pvc conduit through this space and attach it ot the ceiling with some hangers instead of TWO conduits.
    But obviously this is out if the pipes touching each other will have a negative impact.
    Thanks in advance!
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    If they are touching each other for the better part of the run you could get a heat transfer from the hot to the cold.
    John
  4. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    By code they must be separated.
  5. hj
    If you want "warm" cold water, and "tepid" hot water run them together so they can affect each other. Otherwise separate them.
Similar Threads: Should cold
Plumbing Forum, Professional & DIY Advice Cold Water when it should be HOT Feb 24, 2005
Plumbing Forum, Professional & DIY Advice hot water when it should be cold Sep 27, 2004
Plumbing Forum, Professional & DIY Advice Should I replace copper pipe? Mar 14, 2017
Plumbing Forum, Professional & DIY Advice Box Out - Dap Out Empty? Shouldn't there be a pipe here? Mar 5, 2017
Plumbing Forum, Professional & DIY Advice How should this humidifier overflow be plumbed? (pics) Jan 24, 2017
