shorter length toilet needed
Discussion in 'Toilet Forum discussions' started by irmatodd, Apr 6, 2008.
  1. irmatodd
    irmatodd New Member
    Apr 5, 2008
    I just replaced the toilet in my 1/2 bath with a round front low flow. It works great. However, it's located near a door that provides access under the stairway where the hot water heater is and now I can't open the door. I got the rough in right at 12", but never thought about the length/depth which blocks the opening. The space from the back wall to the door opening is 24" which would be along the side of the toilet. I found that there are toilets with a length of 26-3/8" and 26-3/4", but will that size solve my problem? The installers hauled off the old one so I don't know what the length was on that one.
  2. hj
    toilet
    The length of the toilet is not what you have to be concerned with. You need the dimension from the bolt holes to the front of the toilet, because that is what will determine how much room you have for the door to open. Most round front toilets will have the same overall dimension because that is just the way they make them
  4. meaw
    meaw New Member
    Apr 19, 2008
    Canada
    I think you should consider this toilet. Saniflo 023 Sanicompact 48 One Piece Macerating Toilet 18-3/4in Depth.. it's more expensive but it saves you a lot of headaches...
  5. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    How about a pocket door, folding door, removable panel instead of a door, etc.? I think it'd be easier to re-engineer a little-used door than the plumbing, but it depends on your specific situation. If it's really little-used, just pull the hinge pins when you need to get in there. I'd be more concerned about how you're going to get the water heater in our out if it should ever need to be replaced, but it wouldn't be unreasonable just to plan on pulling the toilet for this once-in-a-long-time event.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Pocket doors can really save space in a small room. I have two bathrooms and both have pocket doors. The alternative of having the doors swing outward was not very attractive.
Similar Threads: shorter length
Toilet Forum discussions You've heard this before - offset flange versus toilet with shorter rough-in Aug 24, 2012
Toilet Forum discussions Length of stiff but flexible plastic pipe prevents bowl scratching by metal snake Nov 22, 2013
Toilet Forum discussions Lengthen 14" Unifit adapter? Jun 1, 2013
Toilet Forum discussions 14" Rough Toilet with approximately 28" length (or 29" max from the wall)? Apr 19, 2013
Toilet Forum discussions Rough in length Jul 10, 2010
