Brian Gamotis
First time well owner here.
I am adding a pit less adapter to my well. Unfortunately my pump only sits about 6" off of the bottom of my 40' well so I don't have enough room to just screw the adapter into the end and then lower it down to the new penetration.
Can I just cut my drop pipe and glue on a schedule 80 adapter fitting?
I'm worried that the joint won't nessecarily hold up to the weight over time.
If it needs to be threaded will a standard pipe threaded work or do I need one specifically for pvc?
I have also toyed with the idea of clamping a cable to the drop pipe below the new fitting and hooking that around the pit less adapter to support everything.
