Short Duct Run to Bathroom Has Little to No Air Flow
Discussion in 'HVAC Heating & Cooling' started by kailor, Jun 7, 2011.
  1. kailor
    kailor Member
    Dec 2, 2010
    Huntsville, Alabama
    I have a 3' straight duct run from the main trunk in a mobile home to a bathroom. It just does not have any air moving throuh it! How can I vastly improve the air flow into the bathroom?
    Thanks.
  2. jadnashua
    You may need a deflector in the main to direct air there. Or, put a booster fan in the duct.
  4. TheycallMeDave
    TheycallMeDave New Member
    Jul 9, 2011
    Retired HVAC Owner/Tech
    Northern Florida
    First, id make sure that tiny diameter duct isnt partially restricted with debris inside it (or partially crushed) ... then id run a larger diameter duct providing you have access to the main trunk duct where the branch duct is attached. You may want to run something fairly flexible thru the duct opening back to the main duct to make sure it is fully open without restriction.
Similar Threads: Short Duct
HVAC Heating & Cooling Can a bathroom vent exhaust duct be TOO short? Jan 30, 2017
HVAC Heating & Cooling New Thermostat Short Cycling A/C Jul 24, 2016
HVAC Heating & Cooling Shortening baseboard radiator Oct 19, 2015
HVAC Heating & Cooling Mitsubishi Mini split -should I worry more about enough heat or short cycling? Dec 6, 2013
HVAC Heating & Cooling Honeywell ST9103A1002 integrated oil furnace fan control board shorting out Mar 9, 2012
