Hello All,
My pressure switch was broken and apparently was never clicking off. I realized this when taking a shower and the water shut off due to short cycling. I replaced the broken pressure switch, and the switch is working properly. However, the pump is continuing to short cycle. It will not run all the way to 60 psi. It shuts off two or three times before reaching the pressure shut off. Does this mean that the pump needs to be replaced? Are there any other things I can try to remedy the problem. Thanks for your help in advance.
