Shopvac dead - fusible link?
Discussion in 'Electrical Forum discussion & Blog' started by coopns, Aug 1, 2013.
  1. coopns
    coopns New Member
    Sep 25, 2006
    Massachusetts
    ShopVac suddenly stopped. Took it apart and after some research looks like a fusible link. Do I buy that or make one? Should those two metal ends in the picture be connected? If so, how and with what.
    I hooked on the multimeter and it made a sound/number moved when I put a piece of copper between the two end connectinos. It looks like those should be connected at the ends there ...Please advise. Go gentle now, just learning.
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
  4. coopns
    coopns New Member
    Sep 25, 2006
    Massachusetts
    Where would you buy such a thing? Would they have them at the big box stores or would I have to got to a electrical supply company?
    Thanks for the link.
    Coop
  5. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    The Armature does not look to good in that motor.
    It will need to be cleaned up and the brushes should be replaced.
    Protectors open for a reason. You can buy thermal protectors online.
    http://electronics.mcmelectronics.com/search?w=thermal fuse
    It would be better to get the original parts from the manual if you can find them.
    Good Luck.
  6. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Throw the damn thing in the trash and buy a new one
  7. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That may be a good idea.
    Most likely the bearings are in need of replacement also.
  8. jadnashua
    There's probably a good reason why the fusible link blew: bearings, brushes, dirt, worn insulation, etc...sometimes it's not the best idea to patch it back together.
  9. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Laughed so hard tears rolled down my leg:D
Similar Threads: Shopvac dead
Electrical Forum discussion & Blog GFCI replaced, now regular outlet is dead Feb 14, 2016
Electrical Forum discussion & Blog Three Dead Outlet Mystery Jun 14, 2013
Electrical Forum discussion & Blog 3-way dead switch Sep 22, 2012
Electrical Forum discussion & Blog Back to hot docks and 2 dead kids.... dock wiring Jul 13, 2012
Electrical Forum discussion & Blog Dead Outlets Jul 7, 2012
