Shellback Laundry Pump
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by msjagman, Mar 8, 2005.
  1. msjagman
    msjagman New Member
    Mar 8, 2005
    My Shellback Laundry Pump Does Not Work On Auto Switch.
    I Must Turn Pump On Manually. I Checked To See If There Was Some Dirt Or Lint But I Do Not See Any The Small Clear Tube On Top That Goes From One Brass Nipple To The Other Brass Nipple. I Checked Out To See If It Had A Problem. I Removed One Side And Blew Air Into The Tube And With A Full Sink Of Water The Auto Switch Came On But As Soon As No Air Was Going Threw The Tube The Auto Switch Wouldn't Work. I Wanted To Know If I Purchase A New Diaphragm And Gasket From The Company Should This Fix My Pump So The Auto Switch Will Work Again. Please Let Me Know Before I Purchase This. The Pump Works Fine On Manual.
    Thanks Msjagman
Similar Threads: Shellback Laundry
Pumps and Tanks Well Forum & Blog. Water is life. shellback auto pump, under laundry tub Feb 27, 2005
Pumps and Tanks Well Forum & Blog. Water is life. shellback pump Mar 1, 2006
Pumps and Tanks Well Forum & Blog. Water is life. upwards laundry room drainage Jan 19, 2012
Pumps and Tanks Well Forum & Blog. Water is life. pump under laundry tub works intermittently Oct 30, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Sticky laundry pump May 30, 2008
