Shed chimney/ "flue" leaking (pics)
Discussion in 'HVAC Heating & Cooling' started by jeremytl, May 22, 2008.
  1. jeremytl
    jeremytl Scientist
    Jan 17, 2007
    scientist
    durham, nc
    Greetings friends: I hope this isn't too off topic for this forum. Here's whats going on: I have a potbelly stove in my shed with a 6" standard flue pipe going up through the ceiling. When it enters the attic of the shed, it is double-walled from there on through the roof. (See pics attached
    It has been leaking for a few months now so I went into the attic to take a look and I could see daylight in a few pinhole-sized areas around the OUTSIDE perimeter of the double wall. So, are there any options to patch it with some kind of heat tolerant caulk or do I need to tear up the flashing and redo the whole set-up? The shingles are fairly old and if I can avoid opening a can of worms, thats ideal. Thanks in advance.
  2. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    The acids and moisture have "used up" the galvanizing coating.
    I would paint the top with "stove paint"
    Edit:
    I would also cut the shingles back about 1/2 inch on the top side so that the shingles are not in contact with the pipe.
    Then paint...
  4. hj
    vent/flue
    If that is conventional class B double wall it is not for use with a wood burning stove in the first place. In fact you should have triple wall pipe with the air spaces between the layers.
Similar Threads: Shed chimney/
HVAC Heating & Cooling Chilly Finished Basement Needs Cold Return? Mar 26, 2014
HVAC Heating & Cooling Help choosing insulation for shed Nov 2, 2011
HVAC Heating & Cooling Flushed radiant water heater, now confused Jul 3, 2008
HVAC Heating & Cooling Heating My Shed Natural Gas Oct 28, 2007
