Kiko
I needed to replace some bad 1" plumbing coming off of the irrigation pressure vacuum breaker on the side of my parents' house. The winterizers didn't shut off the valve tight enough, and the elbow coming down from the PVB split. Since it was soldered, I had to cut the 1" copper to unscrew this bad elbow. I soldered on a 1" stub to the new elbow and screwed it into the PVB. The pipe ran very close to the house, so, instead of trying to solder on a coupler, I used a 1" shark coupler. There was almost no play in the pipe, so getting this push fitting over both ends was VERY difficult. I ended up cutting away more pipe than I would have liked, but it doesn't leak.
1. Is there a push fitting that retracts about 1/2" to help get it over pipes with no play in them?
2. If I were to have soldered on a 1" coupler without stop, how do you keep the coupler from slipping down on this vertical pipe? I was thinking of using some bailing wire to keep it in place, or does the flux itself keep it from slipping down?
