Sharkbite/pex problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dsmarian1, Jul 16, 2007.
  1. dsmarian1
    dsmarian1 New Member
    Jul 16, 2007
    A new member and DIY'er here. I am having to replace several galvanized pipes in my old house. I have created a preliminary system that I have not yet attached to my main system. I am using Zurn PEX and Sharkbite fittings. I am running it parallel to the existing pipes and using zip ties tor temproary support. I have tested this system attaching it to my garden hose, to check for leaks. Despite the positive feedback I have seen in this forum for Sharkbite my system had numerous leaks. I replaced the sharkbite tee or elbows depending on what leaked and the inner white sleeve ( or whatever it is called) often came out with the pipe when detached.
    Most of the pex I am using is 3/4" with the occasional 1/2" line off for use to attach to a fixture.
    What am I doing wrong? I do not want to use this combination in my house when the time comes to really replace the pipes if it does not work.
    Maybe this is what comes from my work in building haunted attractions, my own home wants to look like the Munsters place with dust and leaks:D
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    Probably the Zurn pipe
    Its probably the Zurn pipe....
    If it came in a roll it probably has an oval
    shape to it...
    i have not heard good stuff about the Zurn pex.
    Its either that or you are not slamming the shark bite all the way into the fitting
  4. lee polowczuk
    lee polowczuk New Member
    May 30, 2007
    Florida
    i would try unhooking each sharkbite with the orange tool and pressing the pipe in again.
    the pipe has to be cut even so it seals properly. the only times i have had a problem with pex is if i try to bend it too much at the sharkbite.
  5. jadnashua
    Did you use their bevel tool to take the sharp edges off of the pipe ends? You may have sliced the o-ring. Is it rated to connect to galvanized? I would think the somewhat uneven outer surface might prevent a good seal.
  6. Cass
    Cass Plumber
    Nov 12, 2005
    Galvanized is not CTS and will not work with sharkbites.
  7. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    You wouldn't even get the Sharkbite on (if so..I don't wanna think of how)...the diameter is larger.
Similar Threads: Sharkbite/pex problem
Plumbing Forum, Professional & DIY Advice Pressure reducer problems Mar 20, 2017
Plumbing Forum, Professional & DIY Advice Water softener problem after power outage Mar 14, 2017
Plumbing Forum, Professional & DIY Advice Adaptor problem with toilet 3/8 Compression & 7/8 Ballcock Mar 9, 2017
Plumbing Forum, Professional & DIY Advice Cooktop exhausts through thinwall tube though foundation. rainwater problem Mar 2, 2017
Plumbing Forum, Professional & DIY Advice Closet flange problem! Feb 27, 2017
