Shark Bite Valve ??
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cleveland1, Aug 1, 2008.
  1. cleveland1
    cleveland1 New Member
    May 18, 2008
    Hi All -
    I have a question on what the pro's think of Shark Bite valves and fittings? I can assume most pro's probably hate them, being that they are unconventional, and make it so easy for DIY'ers to do plumbing themselves - however being that I am on a strict budget, and can not afford a plumber this time around, I was hoping for some objectional advice and opinions on these. As unpregidous as possible.
    Anyway - I am faced with replacing the 2 master shutoff water valves in my mother in law's home, right by the water meter in the basement. Both the street side valve and the house side valves.
    Though i have used compression valves plenty of times in the past, and also can sweat (kind of good) - I was hoping the shark bite valves in thsi case, would be great to use, so I can get them replaced quickly, while the city waits for me so they can turn the water back on in the street at the curb.
    And thereby getting it al done quick, and with very minimal inconvenience to me and the residents of the household, etc.
    I used a shark bite fitting once before in my own home, and surprisingly, I was amazed that it actually worked.
    But I am not sure if using one on the main water shutoff would be wize or not? Do they hold up and last as long as conventional valves would?
    Also, I am not sure if shark bite vlaves, although the body is mostly brass like conventional vlaves, will conduct electricity like a conventional valve does. Being that the main water line, is how the whole house is being grounded with.
    I looked closely at one of the shark bite valves (3/4" ball valve), and I can't be sure that the "circuit" will NOT be broken by the plastic and steel push fitting on each end??
    Any comments??
    Thanks in advance.
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    When price matters more than quality, plumbing will always suffer. Sharkbites are great for fast temporary repairs. they are great for testing. Would I put a fitting with a rubber O ring in it in a concealed wall? Never. Want to have some fun? Cut a 1/2" copper line. Put a sharkbite coupling in place. Turn on the water and then flex the pipe where the coupling is. See the leak? You will. I have a rule. If I can't afford to do it right then I just don't do it. Price should never be the deciding factor. Essentially what you are asking is "Is there an el cheepo way to get out of doing this job right?"
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I use Sharkbites and have a higher level of confidence in them than most of the pro's. I spent a number of years as the staff plumber in an industrial maint. department. We had a large number of CNC machines that used a very similar technology on their pnematic systems. The environment was hot, oily, moving rapidly and a few other hazards among them high pressure. The technology performed well and reliably.
    However, I would sweat the valve on in that application. I use them primarily as a transition coupling and in situations where the water cannot be shut off completely.
  5. Redwood
    Dec 15, 2007
    Service Plumber
    That is something that you need to try before you say it happens!
    If it does there is one reason and that is that you have not inserted the pipe all the way.
  6. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Nope, pipe properly inserted, flex the joint water leaks.
  7. Redwood
    Dec 15, 2007
    Service Plumber
    You are describing something I have never seen.
  8. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    I see shark bites as a sure way to get a customer pissed off about prices.
    I only use shark bites for transition.
  9. Cass
    Cass Plumber
    Nov 12, 2005
    I have seen shark bites leak.
    They will leak when the tubing is not round or is damaged, the OD is not correct, or the O ring becomes damaged.
  10. Redwood
    Dec 15, 2007
    Service Plumber
    Exactly! When flexed they will not leak if the tube was in good condition, and properly assembled. I find the "Second Stage" in to the tube stop is actually in very close tolerance to the O.D. of the tube and does not allow enough "Flexing" to cause any leakage. It is in fact IMO tight enough that tube insertion is difficult.
  11. artsamm
    artsamm New Member
    Aug 2, 2008
    shark bites and code
    Are these fittings generally accepted by code. If so, are there any limitations, such as not to be used in walls or near water heaters? Crawl space and basement only? Kind of curious. I had some work done a year ago and plumber used a few in the crawl space.
  12. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    I think the package they come in say not to use in wall. I could be wrong.
    It is not a good idea to use anything like that in a wall. I don't use compression fitting in walls. Well I tend not to use any compression either.
    Emergency use only I say.
  13. Redwood
    Dec 15, 2007
    Service Plumber
    They are approved for use in concealed locations and underground.
    http://www.cashacme.com/prod_sharkbite.php
  14. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    Thank you for the info Redwood, but I still will not use the in concealed places.
  15. artsamm
    artsamm New Member
    Aug 2, 2008
    Thanks to the both of you for the replys. I'm not a plumber by trade (truck and equipment mechanic for the military) but I do my own remodel work at home and want to do things the right way and to code. Learning these ways helps me to do my work better.
    Thanks again.
Similar Threads: Shark Bite
Plumbing Forum, Professional & DIY Advice Shark bites Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Sharkbite leak on PEX Dec 5, 2016
Plumbing Forum, Professional & DIY Advice Sharkbite Nov 11, 2016
Plumbing Forum, Professional & DIY Advice Sharkbite vs EPC or Mueller Jun 23, 2016
Plumbing Forum, Professional & DIY Advice Warning!! Sharkbite fitting corroding May 17, 2016
