Shark Bite problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by SteveS, Oct 31, 2010.
  1. SteveS
    SteveS New Member
    Aug 1, 2010
    coastal CT
    I'm using Shark Bite fittings to attach to pex rough lines for a bar sink and bath room in newly finished lower level. I'm not being able to fully seat (to the 1" mark) for my 1/2" nominal pex. The pex I'm testing on is new, unmarked, and cleanly cut. Is there something I'm likely to be missing in how I try to push the fitting onto the pex?
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Do you have the proper manufacturer's marking guage? I am pretty sure that 1/2" pex does not insert one inch.
  4. SteveS
    SteveS New Member
    Aug 1, 2010
    coastal CT
    The box in which the 1/2" fittings are packaged does specify 1" in the instructions printed on the inside of the package. I have now obtained the official gauge. It does apply quite a bit more bevel on the end "de-burring" the end, but using it as a marking guide gives a mark at about 15/16", depending on how sharp the marker is. The on-line instructions tell us that the insertion should be to within .005" of the line marked from the gauge. I can't quite meet that tolerance. But, the insertion seems solid and positive, with additional force not giving deeper insertion. Moreover, I went ahead and tried the fittings on the actual rough plumbed pex, and experienced nary a drop when the water was turned on to those lines. I just hope the slight short-fall in insertion depth doesn't mean that longevity of the connection will be reduced.
  5. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    The o ring is where u get the seal so you will be fine.
Similar Threads: Shark Bite
Plumbing Forum, Professional & DIY Advice Shark bites Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Sharkbite leak on PEX Dec 5, 2016
Plumbing Forum, Professional & DIY Advice Sharkbite Nov 11, 2016
Plumbing Forum, Professional & DIY Advice Sharkbite vs EPC or Mueller Jun 23, 2016
Plumbing Forum, Professional & DIY Advice Warning!! Sharkbite fitting corroding May 17, 2016
