Shared Artisian Well Electric Consumption
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by invisible-man, May 26, 2009.
  1. invisible-man
    invisible-man New Member
    Jun 16, 2008
    United Kingdom
    Hi,
    Hope someone can help,
    We share an Artisian well with a neighbor (quite common I know) it appears that the water supply splits under the ground, then runs to each of our properties......our property has the pressure switch and bladder tank, our property also supplies the electric to run the well pump.....
    A few months ago the well pumps switch stayed on for three months leaving me with a huge electricity bill.
    Also, another problem, I cannot winterize fully in winter as I have to leave the well ready to use for our neighbors, this being leaving the pressure switch pressururized etc etc, this leads to other problems of having to heat our basement.
    I am trying to find out if this is the standard or only way of setting up a shared well, one pump, one electricity supply etc....or is there another way of setting the shared well up so that each property are in control of their own water and electricity supply, electricity supply at least......or a fairer setup if you like?
    Many thanks, much appreciated
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Two pumps, two tanks, two pressure switches with electric from each home. One well shared. Then of coarse you will need a place for these pumps and tanks etc.
    This is all assuming two pumps can be retrofitted to this well that we know nothing about.
  4. invisible-man
    Jun 16, 2008
    United Kingdom
    Do the pumps go above one another?
    Sounds expensive....any guidance on price?
  5. hj
    pumps
    Unless it is a very large well casing, you cannot fit 2 pumps into it. Even if one would fit above the other, you still have to deal with the pipe from the bottom one. You could create a very complex switching system in which either house could start the pump according to need, and then lock out the other house's electrical supply until the first one's demand was satisfied. Where did all that water go if the pump was running for month's on end?
  6. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Put a water meter on each house and divide the cost accordingly.
  7. invisible-man
    Jun 16, 2008
    United Kingdom
    Thanks hj
    Sounds as though this would be cheaper than the first reply, any idea of price for this way?
    Hmmm, in regard to where the water went, we are the lower of the 2 properies with the artisian well between, we do get plenty of water in our sump pump throughout the year (comes in the side of the sump via pipe), don't know if this could be some kind of overflow from the well.....property was not occupied during the time of the well pump staying on, spring time (holiday home), during this time according to neighbors checking, the basement floor was wet........
    Now because I have only owned the property for 18 months or so, not sure if this could have been caused by the pump staying on or natural spring time weather conditions causing this........During the summer the sump empties every 10 minutes or so but apparently at this time of continous running well pump, the sump was continously emptying....
    Would love to find out if the Artisian well has an overflow under the ground somewhere.....was also not sure if a Artisian well pump was to run continous whether water would have to come out of the well or not.
    Sorry so many questions, love to have some answers !!!
  8. speedbump
    Jul 15, 2005
    Riverview, Fl.
    If your pump runs for over 20 minutes without moving any water, it will nuke. You must have water going somewhere if the pump didn't shut off.
    Do you know what kind of pump you have? Jet or submersible? Do you know what size the well is?
    Artesian wells do not necessarilly flow. Artesian means the well has a static water level.
  9. invisible-man
    Jun 16, 2008
    United Kingdom
    Hi, speedbump
    Unfortunately, do not have that information, did try and look at the local records a few months back but could not find any information.....it is a submersible as it is not above ground, only a couple of feet, about 4" - 6" round with an offset shape on one side (silver color cap).
  10. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Now, I'm really confused.
  11. invisible-man
    Jun 16, 2008
    United Kingdom
    Sorry, I mean the pump is not above ground.....the head of the well is approx 2' above ground.
  12. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    That and a written contract between neighbors outlining each others responsibilites would solve the problem.
  13. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Yes a written agreement would be a great idea.
    The pipe sticking up must be a pitless adaptor, so the well does not flow.
  14. invisible-man
    Jun 16, 2008
    United Kingdom
    How come the pump did not burn out I wonder?
    I was thinking that there maybe an overflow underground from the well straight into our sump as it has a plastic fitting...would this be possible do you think or not?
  15. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Nope, the well and the sump have nothing in common. It's hard to tell why the pump didn't burn up, it should have unless water was running somewhere.
Similar Threads: Shared Artisian
Pumps and Tanks Well Forum & Blog. Water is life. Shared well setup advice Jul 3, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Install extra storage tank for shared well? May 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Shared well, water pressure jumps up and down May 15, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Small subdivision shared well. Feb 17, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Shared well pump, we are paying fully Jan 13, 2015
