Sharbite fittings - leaks from teeth marks after making & breaking?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by AcidWater, Nov 13, 2008.
  1. AcidWater
    AcidWater Member
    Oct 14, 2008
    That should be SHARKbite fittings. Wish I could edit the title...
    I just cut away some pinholed copper and inserted CPVC in the gap. In the process of fitting the whole thing, I had to make & break a Shark slip connector a couple times. It leaked, and I can see the gouges in the CPVC.
    In order to disassemble the whole jigsaw, I had to remove a Shark connector from the left end copper "stub" and also the slip connector from the right side copper "stub."
    I can cut new CPVC to make sure its smooth, but I can't cut the copper back anymore.
    The copper on the right side has some tooth marks -- shiny copper lines on the old tubing; they don't look deep at all
    So are they going to leak?
    I have nothing better to do tonight than give it a try, even though getting this together is a real jigsaw puzzle even using Shark connectors -- due to interferences it only fits together in one sequence, piece by piece..
    Maybe I can reverse the slip connector so the slip side is over the tooth marks; maybe it seals further into the connector...
    So far I don't see the advantage of Sharks over compression fittings.
    EDIT: I wonder if the tooth marks on the copper happened when I made the connection. They only give you one "removal tool" and you use that on the slip side when making it. If I had used a second one on the copper side at the same time when making it, maybe the marks would not have occurred. But in that case, the marks don't cause a leak...
    EDIT 2: Nope, not leaking.
    But I discovered that the inner plastic sleeve on the fittings will fall downwards and prevent the pipe from being inserted. If you muscle it, the sleeve can get mangled. I used an awl to cram it into a nearly centered position and make sure it was stuck there.
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Regular pliers <> Removal tool
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    If you don't press in the locking ring enough it will make gouges when you pull it apart. Gouges = Leaks.
  5. hj
    sharkbite
    REmove the sleeve for copper tubing. Crescent wrench is a better removal tool than pliers.
  6. AcidWater
    AcidWater Member
    Oct 14, 2008
    Pliers give less leverage, especially when your hand is up in the overhead. And when the pipe moves, would probably gouge the tube.
    I recall reading that the insert can be removed for some purposes, but the packaging says nothing about it. Removable for copper only? What about CPVC?
    The slip side of the slip connector has no sleeve to begin with.
  7. Redwood
    Dec 15, 2007
    Service Plumber
    The stiffening insert is only used on PEX.
  8. vlee1973
    vlee1973 New Member
    Oct 5, 2010
    Wisconsin
    What happens when you don't remove the sleeve when attaching the sharkbite to cooper? I'm asking because I did it.
  9. Redwood
    Dec 15, 2007
    Service Plumber
    Don't worry about it but they are only for use with pex
  10. hj
    It just makes the opening in the pipe smaller.
Similar Threads: Sharbite fittings
Plumbing Forum, Professional & DIY Advice What fittings are there for polybutylene pipes? Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Uponor PEX with non-ProPEX fittings Nov 1, 2016
Plumbing Forum, Professional & DIY Advice Viega press fittings for PEX Sep 12, 2016
Plumbing Forum, Professional & DIY Advice Spinning PEX fittings Sep 3, 2016
Plumbing Forum, Professional & DIY Advice Compression fittings for 3/4" and 1" Jul 12, 2016
