Shallow Well
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Hank, Apr 22, 2007.
  1. Hank
    Hank New Member
    Apr 22, 2007
    I need some help. I replaced my gould shallow well pump and tank. I primed the system and the pump runs and the tank pressurizes to 30 psi. As soon as I turn on the hose the pressure drops but the pump will not come on. I replaced the pressure switch but I have the same problem. I can walk away from the pump and after 20 minutes or so the pump comes on pressure to 30 psi and shuts off. There is not a leak because if I leave the pump alone the pressure stays at 30 psi. Why can't I keep a suction when I open the nozzle on my hose? Anyone have this problem or seen it before?
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    What did you replace your Goulds pump with?
    Why do you have your switch set to shut the pump off at 30 psi instead of 50 or better?
    bob...
  4. Hank
    Hank New Member
    Apr 22, 2007
    I replaced the pump with a the same model Gould J7 3/4hp J+ convertible jet pump.
    What I don't understand I don't think I have any leaks because when the pump comes on the bladder pressurizes to 30 psi and it holds. Only when I open the hose the pressure goes south and the pump won't turn on.
    You asked why am I cutting the pump off at 30 psi and not 50 psi or higher.
    How do I get the pressure up to 50 psi?
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    You can adjust the pressure switch. If you send us a picture or describe the switch, someone can tell you how.
    My biggest question is with a new pump; how did it get set at 30 psi off in the first place?
    bob...
Similar Threads: Shallow
Pumps and Tanks Well Forum & Blog. Water is life. I need a little more pressure in my life... shallow well issue Today at 9:41 AM
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well jet pump failing to reach cutoff Feb 15, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well pump installation Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Shallow Well Advise Jan 15, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Shallow Well Jet Pump Recommendations? Jan 4, 2017
