lol, you are of course likely correct.
There is no valve on the 'dump end' in the tank . . . when the pump runs, it will flow (in either direction). I figured a check-valve may be required to keep the water in that 40ft of pipe from coming back on the pump. But that is an assumption by me...maybe it doesn't matter and I should remove?
'Well valve' is just a ball valve to 'close' the well if the pump is removed. I really don't think I need it.
