shallow well pump won't shut off
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by pony, Jan 23, 2007.
  1. pony
    pony New Member
    Jan 23, 2007
    Hello, I hope someone has some suggestions. My house was built in the 1970's, and we bought and moved in about 4 years ago. It has a 20 ft. well, and the pump is under the house. We started using the well about 4, 5 months ago. A while ago, the faucet started sputtering, and we realized the well level was low. The pump ran a while before realizing. After the well water level raised, we turned pump on again, no water, (obviously we're new well users), so we primed it. It pumps water, but will never shut off. We have to kick the breaker to shut it off. When it is shut off, no water.
    One fellow said the tank may have too much air. The tank isn't a bit heavy, so I'm thinking that may be it. How do I let air out? Also, my one bathroom sink doesn't have hardly any water pressure, but all others in the house does. The tub in the same bathroom does, and the bathroom faucett that has very little pressure, is very old and needs replaced, so I inclined to think that isn't the problem.
    Any suggestions?
    pony
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Hi Pony,
    You might have done some damage inside the pump since it ran for a while before you caught the problem. Heat is a big enemy of jet pumps. If it got hot enough, the impeller or nozzle/venturi might be damaged. Or you might have a plugged jet.
    bob...
  4. pony
    pony New Member
    Jan 23, 2007
    Hi Bob,
    Thanks for responding. But, how do I check this? Also, if there is too much air in the tank, what do I do to let some out? There isn't a gauge on this tank either, and the valve stem, I cannot press anything at all down in it to relieve air. I know that doesn't sound right...
    Sorry I don't know too much about this.
    Pony
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Maybe it has no air. Do you have a tire gauge. If so, check it just like you would one of your car tires. If no air, you will need to pump some in with and air compressor.
    This won't help the pump any though. If it won't build pressure, you either have a horrendous air leak or the pump is damaged or you may have a plugged jet which would in either instance mean disassembling it.
    bob...
  6. pony
    pony New Member
    Jan 23, 2007
    Bob, where is this propeller, or jet, that may be stopped up?
    Pony
  7. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Inside the pump. You have to seperate the two halves to see the impeller and jet. Some pumps have the jet on the front held on usually with two bolts.
    bob...
Similar Threads: shallow pump
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well jet pump failing to reach cutoff Feb 15, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well pump installation Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Shallow Well Jet Pump Recommendations? Jan 4, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Filter before shallow well pump? Dec 19, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well pump w/ 1"intake May 23, 2016
