Frank lammers
Can anyone recommend a shallow well pump with 1" intake
Be advised that my 1" is being gravity fed from 500 gal. Tan 100 ft. Away. Does that change thingsIt is not the size of the pump intake that matters. It is the distance and volume needed. Your pump will see the friction loss from the small pipe as the well being deeper, and it just won't pump as much water. All pump manufacturers recommend increasing the suction pipe size in most cases. Even though the pump has a 1 1/4" inlet, they would recommend a 2" suction pipe if the distance is very far.
One thing that will help with a small suction line is a CSV and a small pressure tank. With the "old traditional pressure tank only systems" the pump is producing max flow until the tank is full. You may only be using 3 GPM, but the pump fills the tank at 15 GPM or whatever size pump it is. If 15 GPM is more than you can suck through the small suction pipe, it will cause low NPSHA and cavitation, which is not good.
When using a CSV and a small tank, the pump is only producing as much water as you are using. So when you are only using 3 GPM, the pump is only producing 3 GPM, which is low enough flow even in small suction pipe to prevent NPSH problems and cavitation.
Your other thread said "Be advised my tank is 125 ft away with 15 ft of elevation."Be advised that my 1" is being gravity fed from 500 gal. Tan 100 ft. Away. Does that change things
I rarely find a thread where the CSV would not be advantageous for the problem being discussed. Do you not see an advantage to drawing a steady low flow rate rather than cycling with a regular pressure switch where it would be drawing maximum flow then zero flow through a long and small suction line?Do you really have to turn every thread into a CSV thread?
I will have about 6 psi head pressure at in take and the pump I purchased has 7.2 GPM at zero lift. I planned on using 32 gal. Pressure take so that it would not cycle often. What size tank would you recommend and do you know of a quality pump with 1" intake.Do you really have to turn every thread into a CSV thread?
Sorry I just looked up what a CSV was. Could you recommend a quality CSV pumpI rarely find a thread where the CSV would not be advantageous for the problem being discussed. Do you not see an advantage to drawing a steady low flow rate rather than cycling with a regular pressure switch where it would be drawing maximum flow then zero flow through a long and small suction line?
The CSV is a control for the pump, it is not a pump. A 32 gallon tank holds about 7 gallons of water, which will give you a 1 minute run time with a 7 GPM pump. And at 7 GPM you only have about 1.5 PSI loss in the 125' of 1" suction pipe, which is good. With only a 7 GPM pump and not having much friction loss in the 125' line, a CSV is not as helpful as when you have a 15 GPM pump or more.
What pump do you have? 7.2 GPM sounds very low for a jet pump. Must be a little 1/2 HP.
How much pressure will be in your pressure tank? 30, 40 PSI? So the higher pressure water pushes back through the pump and pipe toward the elevated storage tank, until the pump goes on again.Do I need a check valve if there's at least 6 psi at Inlet
Thank you for everything.A JS5 regular jet pump like reach mentioned would be best. Just add a little 20-30 gallon pressure tank and you can probably run the pressure switch at 40/60 just fine. And yes you need a check valve. Best to put it on the suction side if you don't want to move the pressure switch that comes with a JS5. Just neck it down to 1" with a bushing.
