bubbalooey
I have a 1hp Myers shallow well pump 25ft deep working for 15 years, had small issues with pressure switch off and on, either adjusted or replaced. Now just installed new pressure switch because the old one contact points had broken off. The pump will reach 60lbs but when water is turned on will not start pump running, I replaced the hose from pump to switch with no difference. I used to be able to watch the pressure switch move up or down causing it to start or stop, now there is no movement. I can adjust it to come on and water the lawn, but after the last zone the pump won't stop. Do I need a rebuild kit for the pump or a new pump?
